A6 Driverside Engine Compartment Smoking
Old Jan 31, 2012 | 01:56 PM
sal082388's Avatar
Default A6 Driverside Engine Compartment Smoking
Okay, I have a 1999 Audi A6 with 188k miles on it..the oil was probably changed 1000 miles ago. The car then had been parked for about 4 months when i went to go turn it on, within 10 minutes of having it on the engine started to have some smoke on it. There is a slow oil leak coming from the front part of the engine drivers side, but the smoke looks like its coming from the back near the coolant tank, any ideas could it be oil leaking on the hot engine causing it to smoke or is there something going on inside I should not be driving it.
Old Jan 31, 2012 | 02:09 PM
M5S5's Avatar
Tech Certified
Not sure what year your car is or what engine is in it but it probably valve cover gasket is leaking. Could also be a cam plug , timing chain tensioner gasket or coolant bottle leak.
Old Jan 31, 2012 | 03:29 PM
budhani786's Avatar
with 188k your coming close to doing your timing belt once again. when you do so change the valve covers cam chain tensionors cam plugs. it will be OK if you drive your car like this just keep checking on your oil level every week. and get used to the smell lol.
dont change just the v/c gaskets as the leaks will come back within a few hundred miles. go ahead ask me how I know lol
Old Jan 31, 2012 | 04:09 PM
sal082388's Avatar
It's 1999..I didn't post the engine type; it's the 2.8L V6 Quattro.
Old Jan 31, 2012 | 04:15 PM
sal082388's Avatar
how do you know if i change the valve cover gaskets the leaks will come back? lol
Old Feb 12, 2012 | 08:51 PM
sal082388's Avatar
bump!
RichardCVan
Oct 7, 2013 12:56 PM
metallninja
Sep 19, 2011 11:21 AM
Veegard
Oct 4, 2009 03:04 PM
sagarh
Jun 12, 2009 02:33 PM
6speedtt
Aug 11, 2008 10:56 AM
