ABS light on and Brake light blinking
my problem is that only the red brake light on dash is flashing(and beeping). it only happens when i turn my steering wheel to the right, never left. it happens more when it is cold outside. it also doesn't happen every time the wheel is turned, it comes and goes. any ideas?
mpw2.7T has the answer. Based on thatpost last week I pulled my ABS module and sent it to Module Master, Gavin Curtis, and had it back in a week. It cost me $257.00 including module repair and postage both ways and about 3 hours of my time. Personally, I followed Gavin's instructions and dropped the windshield washer tank rather than "bending the pump up" to get access to the 6 torx screws. I installed the repaired module last night, the ABS system is operating perfectlyand I saved about $1000.00.
I am having the same problem of the ABS yellow light and the red flashing light. The guy who sold me the car said that he had just changed the rear rotors at a non audi garage. The garage did not disconnect the battery to do this and thats why he thinks its flashing. Is this true? Sometimes when it is cold in the morning it would not flash and the computer does its diagonistics and would flash the OK sign. But when it gets warmer the lights come on. Any advice as I do not want to remove the ABS module if there is nothing wrong with it.
I had it checked at a non Audi garage but their code reader could not tell them if there was anything wrong with it.
ORIGINAL: magicfan
ABS lights don't flash and give no fault codes, there is something wrong with the module.
I wanted to add to this thread as it did not seem to address the issue when the ABS indication is solid 'ON' and no other brake warning lights illuminated. From reading the threads, there appeared to be consensus of the ABS module being faulty when the ABS warning light on the dash is solid and the brake warning is blinking. I had recently replaced the front right CV boots and complete front end suspension job (upper and lower control arms). After this was done, I experienced a solid ABS (on always). I planned to have mhy local shop realign the front end so I asked them to look into this issue.
They told me the sending unit from the front right ABS sensor was faulty (not sending). I figured I must have damaged it in the reinstall of the CV joint and told them not to bother charging me $200 for a new one plus installation since I could fix it with a $45 replacement from FCP Euro. They must have reset the codes because the ABS warning was no longer showing when I picked up the car. Perhaps the warning popped up as I had the key on a few times during my suspension job (to turn the wheel right or left) and it probably noted the CV was missing (leading to the warning?). Either way, I don't need to repair....unless is comes back on again...and appears unrelated to the ABS Module.
Can anyone tell me the cost to have the abs module repaired? My 2005 A4 has a blinking brake light along with the abs light on solid and the engine light also. The car jumps when I step on the gas. It still runs and stops but it feels very shaky. Oh and the speedometer works intermittently. Am I damaging it to drive it? All the foreign car shops say they cant fix it cuz they dont have the software to code the new replacement parts and I have to take it to the dealer. Any idea the cost for this repair? Is it worth it on a 2005 A4 with 90k miles?
Подробная инструкция о том, как недорого купить шкаф из массива дерева на заказ?
Компания “Массив-Мебель” предлагает на своём сайте широкий модельный ряд различных шкафов из массива сосны, берёзы, бука, дуба на заказ, и у нас Вы без особого труда можете это сделать. Но как это часто бывает, возникла небольшая заминка. Вы никак не можете понять с чего начать. В этом случае мы решили пойти Вам на встречу и помочь определиться с Вашим выбором.Шаг 1. Определяемся с массивом для шкафа на заказ
Прежде чем купить шкаф Вам необходимо ответить самому себе на один важный вопрос - Из какого массива мне нужен шкаф? И в этом случае мы предлагаем широкий выбор наиболее популярных массивов древесины:- Массив сосны, отличный вариант для тех, кто хочет приобрести мебель из настоящего дерева, но стеснён в средствах, поэтому для Вас отличным решением будет раздел “Шкафы из сосны”. Качественные характеристики сосны,такие как прочность и умеренная склонность к короблению, позволяют ей отлично держать крепёжные элементы.
- Массив берёзы очень прочен, поэтому изделия из берёзы не поддаются рассшативанию. Кроме того рисунок древесной текстуры берёзы отличает извилистость и витиеватость. Если Вы давно мечтали приобрести шкаф из берёзы, тогда Вам необходимо зайти в раздел “Шкафы из берёзы” и ознакомиться с представленным в нём ассортиментом, поверьте Вы будете поражены широтой выбора представленных в нём моделей, и практически сразу захотите купить шкаф из массива берёзы на заказ. Проверено нашими клиентами.
- Массив бука, обладает высокими показателями по параметрам твердости и плотности. Если Вы давно искали шкаф из бука, тогда не смеем Вас задерживать на пути в раздел “Шкафы из бука”. Широкий модельный ряд шкафов из массива бука на заказ и высокий уровень качества - это главные достоинства шкафов от “Массив-Мебель”.
- Для тех, кто не привык размениваться на мелочи и считает, что высокое качество и элегантная красоту достойна любых денег, то для них отличным выбором будет массив благородного дуба. Древесина дуба обладает крупной и очень выразительной текстурой, которая подчеркивает элитарность изделия и несомненно указывает на Ваш статус в обществе, а ставшие практически легендарными отличное противостоянию биологическому поражению и запредельная прочность изделий из дуба, позволяет нам с высоты собственного опыта говорить о том, что они будут радовать Ваш глаз долгие годы, занимая место в интерьере Вашего дома/квартиры по праву. Звучит крайне интригующе, не правда ли? Тогда не упустите момент и шагайте смело в “Шкафы из дуба”. Модельный ряд Вас приятно удивит, а цены не оставят равнодушными.
Шаг 2. Сколько нужно дверей для шкафа из массива на заказ?
Для тех, кто давно находиться в поиске идеального шкафа-купе, мы советуем, смело идти в раздел “Шкафы-купе”. Поверьте, там Вы потратив малую толику своего драгоценного времени, сможет выбрать подходящий Вам шкаф-купе из массива сосны, дуба, бука, берёзы на заказ.А для сторонников не устаревающей классики предпочитающих, шкафы с распашными дверями, мы можем предложить на выбор несколько категорий подобных шкафов, которые смогут ответить любым Вашим, даже самые смелым требованиям:
- “Шкафы двустворчатые”. здесь Вы встретите различные варианты двухстворчатых шкафов из массива дерева на заказ .
- “Шкафы трехстворчатые”. В этой категории представлен широкий модельный ряд, из которого Вы сможете выбрать и купить трехстворчатый шкаф из массива дерева на заказ.
- “Шкафы четырехстворчатые”. Данный раздел отлично подойдёт тем, кто ищет большой шкаф для своих вещей, зайдите и убедитесь сами. Вы найдете, что Вам нужно, и заказать четырёхстворчатый шкаф из массива.
Шаг 3. Функциональные возможности шкафов из массива дерева на заказ
Количество дверей у шкафа Вас не волнует? Вам куда более интересен функционал шкафа? Тогда не будем медлить и скажем прямо, специально для Вас на нашем сайте созданы следующие разделы:- “Гардеробные” и “Для одежды”. В данных категории шкафов служат для хранения различных типов одежды. Заходите и выбирайте шкаф.из массива сосны, берёзы, дуба, бука на заказ
- “Книжные”. Шкафы из данной категории прекрасно подойдёт для Вашей огромной библиотеки. Заходите и покупайте книжный шкаф из массива дерева на заказ, и Ваша библиотека будет не только вместительной, но и элегантной.
- “Для прихожей”, В этой категории мы собрали различные модели шкафов для прихожей из массива сосны, берёзы, бука, дуба на заказ.
- “Буфеты”. Тут вы найдёте шкаф для Вашей столовой или кухни.
В разделе “Шкафы угловые” представлены интереснейшие модели угловых шкафов из массива сосны, берёзы, бука дуба на заказ.
Шкафы из массива серии “Верди” и “Лирона”
Вы являетесь поклонником серий “Верди” и “Лирона”, тогда компания “Массив-Мебель” специально для Вас предлагает шкафы данных серий по выгодным ценам, их Вы найдёте в категориях - Серия "Верди” и Серия "Лирона".Хотите добавить в интерьер Вашего дома или квартиры долю элитарной утонченности? Категория “Элитные шкафы” - Ваш выбор.
С компанией “Массив-Мебель” Вы сможете купить шкафы из массива дерева на заказ по крайне выгодным для Вас ценам. Спешите купить мебель компании “Массив-Мебель”.
Вы можете приобрести двери и другую мебель.
HolyokeAudi
Dec 17, 2014 09:13 AM
jasmix
Dec 1, 2007 03:17 PM
