ATQ or AHA Engine '99 Avant 2.8
Old Aug 19, 2009 | 07:01 PM
porschefan's Avatar
Default ATQ or AHA Engine '99 Avant 2.8
Hey Guys
I can't search for only 3 letters on the forum, how can i tell if my engine is ATQ or AHA?
I need to order a new MAF, probably from ECS in the $150 range but i have to know the engine type.
Will it be listed anywhere on the chassis, i have VAG-COM but i'm not sure where to look, didn't see anything in 01-Engine.
Its a 1999 Avant 2.8
Appreciate any pointers, cheers
Old Aug 19, 2009 | 08:16 PM
SkipsA6's Avatar
I have a '99 A6 Avant 2.8 and it is the AHA engine. I am not sure of the difference between the AHA and the ATQ engines? Can anyone else chime in here?
Old Aug 19, 2009 | 09:09 PM
Midniteoyl's Avatar
AHA = Drive By Cable
ATQ = Drive By Wire
I think the short blocks are the same. Things that attach are a little different.
Old Aug 20, 2009 | 12:08 AM
chefro's Avatar
you should be able to look it up behind and under the power steering pump. It is etched on the the engine block lip....which you may need to wipe it clean to see the code.
Attached Thumbnails ATQ or AHA Engine '99 Avant 2.8-eng-code1.jpg   ATQ or AHA Engine '99 Avant 2.8-eng-code2.jpg
Old Aug 20, 2009 | 09:29 AM
nm3210's Avatar
Here's what the engines generally are, but you should always double check (all for 2.8L)
'95-'97 = AFC (12v i believe)
'98-'99 = AHA
'00-'01 = ATQ
To address the original post, however: have you tried cleaning your MAF with MAF cleaner?? It works wonders generally.
Old Aug 20, 2009 | 09:34 AM
porschefan's Avatar
OOpps double post
Old Aug 20, 2009 | 09:38 AM
porschefan's Avatar
Thanks for the reply Guys.
I did have a look there Chefro, but i couldn't see clearly, so i just gave my local Audi dealer my VIN and he said it's an AHA.
Appreciate your help.
EDIT: @nm3210 Yeah i tried that, got the CFC cleaner but no good. My local independent still gets the MAF error
Its really sluggish when on full lock, going round tight corners or pulling across traffic, which they think could have something to do with MAF. They want $345 for a new one with fitting
Old Aug 20, 2009 | 01:20 PM
NH_USA's Avatar
Try looking at Force Five or Blauparts for the MAF
Old Aug 20, 2009 | 06:33 PM
porschefan's Avatar
Actually ordered one from AutoHaus, got free shipping too.
Old Aug 20, 2009 | 11:33 PM
chefro's Avatar
No problem whatsoever, you're welcome.
irishstratfan
B8 Models
Feb 23, 2015 02:24 PM
pg12
Jul 25, 2013 08:11 AM
brianhill33
Aug 29, 2009 12:56 PM
M.Reid
Sep 1, 2008 11:46 PM
daltvater
Nov 21, 2006 01:07 PM
