Audi A6 with bad battery or alternator
Old Mar 4, 2012 | 01:12 PM
02A6Beau's Avatar
make sure you clean the battery tray drain so the problem doesn't come back
Old Mar 4, 2012 | 01:16 PM
rodhotter's Avatar
a battery with internal shorts can be good or bad off and on, most batteries do not last over 4 yrs anyhow, i try a new one
Old Mar 4, 2012 | 03:29 PM
bigdadi's Avatar
New wipers every year & new battery every 4 years is good maintenance, just like oil / filter change...
Old Mar 5, 2012 | 09:53 AM
audia6s's Avatar
I understand and agree but after i dried up the water, problem kind of went away. Atleast for now. 2nd day and I didnt have to use a jump start in the morning.
I just have to get the seal replaced so that water doesnt get inside.
Old Mar 6, 2012 | 01:07 PM
audia6s's Avatar
So does anyone know if water next to the battery can cause it to drain or fail? It's been working fine since i dried up the water. Was that just a fluke or i should still look into replacing the batt. even though its working fine and the NTB test came out clean too. Thanks
Old Mar 6, 2012 | 01:31 PM
Tourbo24's Avatar
I wouldn't worry about it then, if drying up all the water helped then that must have been the problem.
Old Mar 6, 2012 | 03:03 PM
ppgoal's Avatar
I suppose it is possible for the water, which conducts electricity, to partially drain the battery. I would say wait it out. If NTB checked the battery and the alternator and they passed, I would not spend the $$ to replace them. I have both of mine checked annually at Autozone. I replaced the alternator at 75k (it failed hard after hitting a pot hole) and am running the original battery at 204k miles!!! I know the manufacturers are all cutting costs and quality, but I would expect more than 4 years out of an Audi battery.
Old Mar 6, 2012 | 03:05 PM
  #18
ppgoal's Avatar
Old Mar 6, 2012 | 04:30 PM
  #19
audia6s's Avatar
Awesome...I'll wait and see. Hopefully problem won't come back and I'll replace the rubber lining so that water never gets inside. Thanks
blu.suede
S4
Apr 21, 2015 12:38 PM
lowell513mx
Apr 27, 2009 08:16 PM
Ph3N0m
Oct 30, 2008 03:21 PM
mandito1980
Jul 9, 2008 10:47 PM
jaykup
Jan 10, 2008 01:01 PM
