Sponsored by:
Sponsored by:
Audi A6 runs for 5 minutes then quits
Old 04-07-2009, 10:15 PM
camsystems's Avatar
Default Audi A6 runs for 5 minutes then quits
I have a 1995 Audi A6 (with a new Coil Pack) that will run for 5 minutes then stop. I can wait a couple of hours and it will start and run for 5 more minutes. Any suggestions where to start?
Old 04-08-2009, 12:47 AM
djez016's Avatar
fuel filter
Old 04-10-2009, 05:05 PM
camsystems's Avatar
Default New Fuel Filter
I replaced the Fuel Filter and the car till has the same issures. What next? Would the cat. converter cause the problem?
Old 04-10-2009, 08:07 PM
zippy_gg's Avatar
At that point I would look at the fuel pump since you already replaced the filter.
Old 04-10-2009, 11:49 PM
Midniteoyl's Avatar
Temperature Sensor. Last time mine did this I was told to replace everything from fuel pump to the MAF. Turned out to be the coolant temp sensor. It failed LOW so the ECU thinks its -40 and when the car warmed up after 5-10 mins would shut off due to the coolant and air temp sensors not agreeing.. Wouldnt restart for 2 hours.
Old 04-11-2009, 01:59 PM
camsystems's Avatar
Default More Information
Thanks Guys for the imput. I will certainly check them out.
Someone else suggested that since the coil pack was misfiring, (2 out of the 6 wasn't working) that may have clogged the catalytic converter. How likely is this? And how do I test for that?
Old 04-11-2009, 02:36 PM
NH_USA's Avatar
A clogged cat would exhibit the problem your seeing but I think it would throw a code of some type. The test would be how quickly it will restart. If it is temp related it would take awhile if it is the cat it would restart in a few minutes.
influentialsonny
11-13-2013 06:30 PM
rwhans007
11-06-2011 06:07 PM
A4 of turmoil
09-22-2010 10:32 PM
ttoo cool
03-22-2007 12:41 PM
Quick Reply: Audi A6 runs for 5 minutes then quits
