Buzzing Alternator when engine OFF
Neither of my Audis have a buzzing alternator. In fact, I've never had a car make alternator noise. If you're in the states, I'd bring it in to an Autozone or equivalent and have the alternator and battery tested for free. But the 2.6 sounds like a European engine spec, so not sure what to suggest (unless you meant to type 2.8).
An alternator shouldn't make any noise when it stops and there is no power to it. Does you battery run down after awhile? If there was an internal short in the alternator, I would expect the battery to drain.
Where, on the 2.8, is the vacuum canister? The parts drawing shows it but doesn't say where it is located. It could be the canister or a hose leaking vacuum.
Bob
Bob
TwoDraft
Jan 24, 2011 03:28 PM
Deezzel
Nov 30, 2008 08:26 PM
