C6 headlight adjustment
Yes they can be adjusted both vertically and horizontally, there should be two little white caps by the headlamp assembly, take the caps off and turn the phillips screws.
However, manually adjusting the headlights requires a vag com scan tool. The reason for this is because the headlamp adjusting motors will just adjust the lamps back to where they previously were unless you perform the basic settings.
To do that you go into the headlamp control module, go into basic settings data block 1, wait for it to say adjust the headlamps, make your adjustment, then go to data block 2 and it should say settings stored.
