C6 headlight adjustment
Old Feb 11, 2009 | 03:34 PM
the G man's Avatar
Default C6 headlight adjustment
Does anybody know if the headlights can be adjusted vertically on a C6 and if so, where is the adjustment screws.
Old Feb 11, 2009 | 03:50 PM
auditech79's Avatar
Yes they can be adjusted both vertically and horizontally, there should be two little white caps by the headlamp assembly, take the caps off and turn the phillips screws.
However, manually adjusting the headlights requires a vag com scan tool. The reason for this is because the headlamp adjusting motors will just adjust the lamps back to where they previously were unless you perform the basic settings.
To do that you go into the headlamp control module, go into basic settings data block 1, wait for it to say adjust the headlamps, make your adjustment, then go to data block 2 and it should say settings stored.
Old Feb 11, 2009 | 04:18 PM
the G man's Avatar
Thanks again Auditech79. So whats the diff. between a $280 vag com scan tool and the one you see on ebay for $30. The one on ebay comes with a disc and a cable and I assume a laptop is needed.
Old Feb 11, 2009 | 04:22 PM
auditech79's Avatar
The vag com is free, your just buying the cable. The difference is the ebay cable sucks and doesn't work half the time. Buy the cable from ross-tech, don't go cheap when it comes to electronics.
Alabet
Nov 8, 2010 11:42 AM
bottlecap
Mar 31, 2009 02:54 PM
Threeputt
Mar 6, 2008 05:57 PM
Elliot_D
Nov 26, 2007 12:50 AM
MiniSpdRcr
Jul 13, 2007 12:50 PM
