cam problem
Old Dec 15, 2008 | 09:37 AM
  #41
beemerfanatic's Avatar
everything for the timingbelt is ok.
i have installed all to day and when i was going to start the engine,the battery was flat..!
i will try again tomorrow..
Old Dec 16, 2008 | 08:48 AM
  #42
i have ordered a new camshaft to day,so i will probably get it on friday.. if that dont fix the problem i will take the car to a workshop...
Old Jan 21, 2009 | 06:45 AM
  #43
now i have got the car back from the autoshop. there was onely a bad timeing on the intake cam on the right side.. strange.. will change the gaskets on the top's,install the bumper.,and hit the roads again and make them unsafe again:-)
so now i hope there will be no more trouble.:-)
Old Jan 21, 2009 | 11:22 AM
  #44
hxgaser's Avatar
Look on the bright side... now it is working again. Have fun driving now.
Old Jan 21, 2009 | 09:54 PM
  #45
auditech79's Avatar
Told you the cam was off timing JK.
Old Jan 22, 2009 | 01:27 AM
  #46
yes,but i got it wrong. the mechanic from audi told me wrong too so when i changed the seals yesterday, i saw that i had missed one tooth. i had it at an non audi dealer and they got it right:-)
all the problems cost me little more money for some extra parts(that i did not need) but now i am happy thats ok. i can just sell the extra parts(chain tensioner,intake cam).
tnx for all the help guys!
Old Jan 23, 2009 | 01:57 PM
  #47
bmcglone's Avatar
How much for the tensioner? I think I may have a bad tensioner in my 2.8.
My intake cam on the left side of the engine has the same alignment problem you had. My engine runs fine, but there is a rattling noise on the left side. I plan to turn the cam one tooth to align the marks.
Old Jan 24, 2009 | 07:56 AM
  #48
my tensioner is for the right side..so i cant help you there..Dont think it's the same on both sides.
if you have a rattling noice,maybe the plastic on the top/bottom of the tensioner is bad? if you turn one tooth the engine will not run fine..!
i have tryed several times with no luck. my last option was a mechanic,and the bastard did it right. c",)
Old Jan 27, 2009 | 12:53 PM
  #49
light351ning's Avatar
OK, gentlemen, sounds like I have a similar problem with my A8. It' has low vacuum at idle (7 - 8 in Hg) / rough idle, has multiple misfire codes on Bank 2, (cylinders 5, 6, 7, & 8) . So it has horrible low speed performance, but runs like it's got a 'Hot' cam. Once the revs reach about 3000, it bursts with power, but low torque down low. I assumed it was an incorrect timing issue from the previous owner not doing a proper job on the timing belt change, but not sure where to start. Because there are no other codes except for the 5, 6, 7 & 8 misfires, does that tell me it is the timing belt that is off, or the bank 2 chain that is mistimed?
Old Jan 27, 2009 | 02:32 PM
  #50
hxgaser's Avatar
I really doubt that it is timing related. Check vacuum lines, coils and the ignition control module.
