Can you just change two tires on quattro?
Old Oct 16, 2008 | 02:43 AM
stevon009's Avatar
Default Can you just change two tires on quattro?
I had a flat and the shop told me that because of the Quattro just changing two tires could ruin the driveline. It sounded like bull just to sell me four tires. Anyone no more on this
Old Oct 16, 2008 | 03:11 AM
alexfunari's Avatar
As long as they are the same size you're fine. They are just trying to make money.
Old Oct 16, 2008 | 03:20 AM
oc_audica's Avatar
didn't have any problems when I ran 2 new/old
i got the same spiel though @ American Tire
Old Oct 16, 2008 | 06:42 AM
Kevin's Avatar
Owner's manual says all 4 tires need to have a diameter within 3/32 of an inch of one another. So if you have less than 10,000 miles on the "old" tires you are probably fine. Of course you can also just decide that you don't care what Audi says and take your chances.
Old Oct 16, 2008 | 09:50 AM
the G man's Avatar
I agree, 10,000 to 15,000 miles is the threshold. Any older than that and mix it with new tires, you are rolling the dice.
Old Oct 17, 2008 | 10:24 AM
euro_2nr's Avatar
No drastic problems will result from uneven tire wear upon the 4. As long as they're all 35,40, 45 ect. Just put the new ones at the front since that's where you need most of your traction. Besides, everything in the Audi manual is exaggerated to get drivers to be paranoid and take their car in to the dealer to get raped
Old Oct 17, 2008 | 12:12 PM
nemohm's Avatar
Try driving on SLIPPERY roads with non-same tires=> this is what the manual refers to, what an AUDI is for.
Old Oct 18, 2008 | 10:22 AM
Bad Justin's Avatar
*stands up and claps* but they don't have to be ALL new, as long as they are TOO diff. in diameter, as stated before.
Old Oct 18, 2008 | 04:02 PM
bob martin's Avatar
Put the new ones on the REAR. That way, in a panic braking situation, the rear will stop faster than the front.
Bob
Josian
Apr 24, 2013 02:51 AM
tkny123
Jun 19, 2010 09:11 AM
mrfredo82
B7 Models
Apr 27, 2010 02:30 PM
FLASHMSTRC
May 23, 2008 11:10 PM
tpb31
Apr 4, 2006 07:00 PM
