car not starting
Old Aug 28, 2007 | 08:45 AM
mancho's Avatar
Default car not starting
I have a A6 3.0 2002. Yesterday after I had been driven the car to work, I came back home and after 30 minutes wanted to start the car again but it didn't. It made a sound like it wanted to start. it had lights, sound and all. the battery indicator showed about 12V, initially but this morning showed like 6V. Is the main problem the battery or is it something else that is killing it. Thanks
Old Aug 28, 2007 | 10:34 AM
EnviedA6's Avatar
Default RE: car not starting
If you have lights and voltage it may not be the battery. If it makes a clicking sound as you're trying to turn it over it will be the starter.
Good luck
Old Aug 28, 2007 | 03:54 PM
madridlover's Avatar
Do the starting problemsONLY happen after the engine has been running for some time? If so your coolant temp sensor could be bad.
Old Aug 28, 2007 | 04:14 PM
techbod's Avatar
it could be the battery is dead or the alternator isn't charging it, a failed alternator will fry the battery through over voltage or simply not charge it up at all so when you are driving your using the battery to keep going and when that's dead you are where you arealternator would be my guess
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
