check engine light
Old Jul 14, 2008 | 03:02 PM
techbod's Avatar
Default RE: check engine light
it will only come back on if there is a problem so if not you sorted it, you might have hit some cold water and that would trigger the rear o2 sensor if the cold water hit it and the CEL has to be reset
Old Jul 14, 2008 | 03:04 PM
reverend's Avatar
how do you reset it? i think it might of gotten bumped when the guys was wiping up from the oil change
Old Jul 14, 2008 | 03:11 PM
techbod's Avatar
if the CEL is on you would need a diagnostic tool like VAG to turn it off
Old Jul 14, 2008 | 04:01 PM
reverend's Avatar
i already did that a couple of days ago and so far it hasn't come back on. should i still be worried about it then?
Old Jul 14, 2008 | 10:37 PM
NH_USA's Avatar
Don't be concerned unless it comes back on.. If I we you I'd check the wires at the sensors to make sure they are on tight. Thye might have been jared loose.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
