clearing engine malf. light
Old Aug 4, 2010 | 12:41 PM
paludi's Avatar
Default clearing engine malf. light
Does anyone know an easy way to reset the system to see if any codes will clear? I would try disconnecting the battery, but it seems too difficult to get the radio code back (manual page is missing) with that method.
Thank in adv.
Old Aug 4, 2010 | 02:19 PM
nemohm's Avatar
One would be surprised if there is any easy way to clear codes - would you be happy if any crook could clear easily the codes 2 min before selling the car to you?
BTW- unless you have an ancient car - there should be no issues disconnecting the battery.
Old Aug 4, 2010 | 03:37 PM
Theiceman's Avatar
..if he disconnects the battery and doesn't have to codes on his car radio he may be pooched ..
Theiceman's Avatar
..besides .. he needs a OBD2 reader anyway to read and clear codes ..
Old Aug 4, 2010 | 06:45 PM
hxgaser's Avatar
Don't worry about the radio code. I never had issue with it disconnecting the battery. Perhaps if you left it off for a couple of hours you may have a problem, but I never had any issue disconnecting it for a several minutes.
Anyways, back to the point, you need an OBD II reader to reset the code.
Old Aug 4, 2010 | 07:49 PM
Theiceman's Avatar
my radio code was written on the options label by a mechanic .. great idea .. so now i do it to all my cars that have codes.
Old Aug 5, 2010 | 12:30 PM
NH_USA's Avatar
Paludi -- you obviously have little knowledge about your Audi.
First the radio code - If you don't have it you'll have to get it from the dealer. Pulling the radio is no big deal. some Audis retain the code for awhile when the battery is off, but some don't. Dealers usually charge $75 -100 for the code.
second CEL -- you need VagCom to clear it. If you don't know what VagCom is do a search in this forum and see what your missing.
Old Aug 5, 2010 | 07:21 PM
ratherb1's Avatar
also you can go to most autoparts store advanced auto, action auto........ they will scan and clear for you for free
Old Aug 6, 2010 | 10:25 AM
NH_USA's Avatar
Most will read the codes but not clear them.. Something to do with liability...
Also you have to be careful with OBDII. It is not VAGCom!
Althought some of the information is common, OBDII has been known to give false info when used on an Audi.
knyks342
Jul 21, 2011 07:21 PM
paludi
Aug 4, 2010 03:39 PM
paludi
Aug 4, 2010 03:38 PM
apollo_kid
Oct 16, 2008 11:59 PM
glock40
Jun 3, 2007 07:59 PM
