CV Joint replacement issue
Old Nov 10, 2010 | 07:49 AM
bob martin's Avatar
rehan1212,
Yes, your CV joints can go bad with no sign of failure of the boots. Extremely rare, though.
Forget about the pinch bolt. Take off the two lower control arms from the chassis and that will give you plenty of room to remove the axle. You have to remove the sway bar end link and then remove the bolt that holds the strut to the front lower control arm. Depending on the side, you may have to lower the subframe an inch but you don't have to remove the subframe bolts, just run them out about an inch.
Good luck,
Bob
Old Nov 17, 2010 | 12:55 PM
rehan1212's Avatar
Okay I got the CV Joint replaced and found out that the tie rod was needed to be replaced as well.... so I was wondering may be it was just a tie rod issue that was causing the click noise rather than the CV shaft as Bob Martin mentioned its extremely rare for the shaft to be bad if the boots are fine...
A6Isaac
Oct 29, 2014 08:19 AM
adam044
Feb 11, 2014 01:07 PM
jchaffee1
Feb 3, 2008 04:00 PM
sntemp
Aug 26, 2007 09:59 PM
Mega_Boost_A4
Jul 13, 2006 04:45 AM
