flush brake fluid
Old Jun 19, 2008 | 12:32 PM
rgall's Avatar
Default flush brake fluid
How do I flush my brake fluid on a 2001 A6 quattro 2.8. I topped it off with bad fluid..
Old Jun 19, 2008 | 06:53 PM
ericgl's Avatar
Default RE: flush brake fluid
Why do you think it is bad?
Old Jun 19, 2008 | 07:29 PM
Cameron's Avatar
By bad fluid, I assume you mean wrong DOT spec. Not sure on the specifics of if you fucked anything up, but just do it like a brake bleed and just keep running fluid through the system. Make sure you don't run the master cyl. dry too. Or you can pick up a power bleeder, hook it up to your air compressor and suck the fluid out. Brake bleeder is a little extreme for one time use, but its great when you bleed/flush brakes all day like I used to.
Old Jun 19, 2008 | 08:04 PM
hxgaser's Avatar
Replace/flush brake fluid every 3 years. Regardless of miles.
ECS Tuning
Oct 30, 2014 03:54 PM
cantdrive55
Aug 8, 2009 01:01 PM
AR15Texan
Jun 10, 2009 12:24 PM
