Got Screwed
Old Jun 6, 2006 | 02:10 PM
Wcc44's Avatar
Default RE: Got Screwed
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 --- Intermittent
They said it wasn't the combi valves... some kind of intake inside the heads?
Old Jun 6, 2006 | 02:12 PM
Wcc44's Avatar
BTW the timing belt / alternator service actually came to 1200 not 1600, sorry.
It would be so wonderful if you were right about not having to remove the heads, but since 3 mechanics have told me the same thing after lots of diagnostics I'm wondering if maybe they are right...
Old Jun 8, 2006 | 02:33 PM
Wcc44's Avatar
Any ideas guys? By the way, I took it back to German Master Tech... they are awesome. They said that the dealer way exagerated the valve leak (its just slightly seeping), and they said i should just wait till next year when I have to do emissions to worry about the CEL. He said if I do my oil changes there, he will keep an eye on it.
Old Jun 15, 2006 | 10:11 PM
steviejayvaughan's Avatar
the cyl. heads clogging up isnt totally uncommon. its just starting to show up on high mileage cars 100k or more. ive seen 1 car w/ this problem. its intermittent, sometimes it will pass the secondary air test and sometimes it wont. at least its something that wont hurt the performance of the car.
Old Jun 16, 2006 | 04:36 PM
A6basics's Avatar
The SAI holes can get plugged with carbon build up and throw a CEL. It's emissions related but only operates during a cold start. It won't affect the performance of the car, but you can't get through emission inspection with that CEL code.
Try asking your tech to flush out the holes with lots of Techron and pipe cleaners...
Old Jun 16, 2006 | 04:43 PM
techbod's Avatar
I had this problem with my old Audi 90 so I blanked the air system with good results an no problems with emissions
Old Jul 22, 2006 | 08:17 PM
StarryTripper's Avatar
I also have a 1999 A6 Quattro 2.8 79K Miles with similar problem (have the 16795+others). Engine light came on. Used VAG-COM to pull codes. This is what I got:
Address 01 -------------------------------------------------------
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06252
Shop #: WSC 02325
2 Faults Found:
P0411 - 35-00 - -
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00268 - Solenoid Valve 6 (N93)
31-10 - Open or Short to Ground - Intermittent
00266 - Solenoid Valve 5 (N92)
I'd appreciate any help. I'm failry inclined mechanically (worked at a shop for a few years) so willing to test things out.
ottomatic
Mar 20, 2009 09:46 AM
ditallow
Apr 3, 2008 12:25 AM
millenia
Jul 15, 2007 12:03 PM
ironman
May 4, 2007 04:05 PM
