Help installing breather hose,W0133-1624629 Breather Hose, on back on engine
Old Apr 30, 2012 | 12:49 PM
copper07's Avatar
Default Help installing breather hose,W0133-1624629 Breather Hose, on back on engine
1998 A6 Quattro, 30v - 178k
I order a new breather hose that goes on the back of the engine. I am trying to rid my car of the infamous p0411 code.
Part number -
I replaced the broken breather hose that connects to the valve covers, still have the code. There is a hose that is about a foot long that installs on the rear of the engine. Does anyone know what has to be removed in order to get the old hose out and install the new one. I don't want to brake anything in the process.
Thanks
Old May 14, 2012 | 12:00 PM
copper07's Avatar
Any Ideas?
Old May 16, 2012 | 12:43 PM
HerrBHB's Avatar
Default My recent experience with breather hose
I just replaced the same hose on my 2001. I was also replacing the "suction pump" following a DIY from another forum. Anyway, I had the vacuum relay panel off - top of engine at the back - to get to the suction pump. For the rear breather hose, I pulled the flex hose on the air intake (downstream of MAF) and the hard piece that transitions to the throttle body. With those removed, I could access the place on the block where the rear breather hose attaches. My car has 140K, so the old hose was quite stiffenned up and I couldn't get the release rings to compress. So I just used needle nose pliers to break the rings and get the old hose off at both the block and the larger breather hose connection.
Old May 16, 2012 | 03:29 PM
copper07's Avatar
I replaced my suction pump not too long ago. Thanks for the tips, I have the hose and hope to get in installed soon. I have the cursed P0411 code, and I think that hose may be the culprit.
Old Aug 15, 2012 | 04:47 PM
copper07's Avatar
I was able to replace the hose but the P0411 still returns. The hunt for the cause of the code continues. I am running out of places to look.
Old Sep 5, 2012 | 10:55 PM
02AudiA63L_65's Avatar
Check and if not replace all your 3.5 mm vacuum lines.
Old Sep 25, 2012 | 12:48 PM
copper07's Avatar
I have done that. I think I will check the 2 plastic hoses that connect to the SAP and see if they need to be replaced.
Old Sep 25, 2012 | 05:57 PM
hxgaser's Avatar
My favorite answer... Check the vacuum line. Check the line from the solenoid to the combi valves.
Old Oct 2, 2012 | 12:10 PM
copper07's Avatar
Line is good there. Still looking for where the leak is. It apparently does not want to be found.
Old Oct 2, 2012 | 04:07 PM
TwinBoost's Avatar
You can try some propane enrichment, just use a torch one not lit obviously and with the car on hear for an increase in RPM. You can also check your one way check valves by simply blowing into them.
SSEI173
May 25, 2014 04:31 PM
bmob222
Aug 30, 2013 03:05 AM
AudimaniaA4
Jan 26, 2008 09:17 PM
joshleahdawn
Oct 2, 2007 11:18 PM
bontyal
Feb 23, 2006 04:03 PM
