Help Replacing Brake Light Bulb 2003 A6
Old Sep 2, 2007 | 11:39 AM
del23's Avatar
Default Help Replacing Brake Light Bulb 2003 A6
Hello. I have a 2003 A6 3.0. My driver side brake light has gone out. Anyone have instructions on how to replace. I searched the board and found instructions for an A6 avant but not the 3.0. I don't need to go to the dealer for this do I? thanks....
Old Sep 2, 2007 | 12:14 PM
techbod's Avatar
Default RE: Help Replacing Brake Light Bulb 2003 A6
Removing and installing rear light
Removing
Switch off ignition and remove ignition key.
Turn light switch to “0” position.
Remove luggage compartment side trim cover.
Unplug connector -6-.
Unscrew nuts -1- and -3 ... 5-.
Squeeze retainer tabs -arrows- at bulb housing -2- and detach rear light outwards.
Installing
Install in reverse order, paying attention to the following:
Note[/align]
Make sure gasket between body and rear light housing provides a proper seal.
Before tightening nuts, align rear light with body contours (even shut lines).
Tightening torque
Component
Nm
Rear light to body
[IMG]local://upfiles/12092/F2B14D55F3DA4ABF8D814CA76FCDCFAC.jpg[/IMG]
Old Sep 2, 2007 | 12:29 PM
del23's Avatar
thanks that is what I found before I guess it just looks different. I haven't taken anything apart yet. I will try right now..appreciate it....
dirtybert1604
Jan 21, 2014 03:41 PM
MagicHobo
Nov 14, 2008 01:37 AM
kmm
Feb 4, 2007 01:21 AM
audiNJ02
May 12, 2006 04:00 AM
derekgardiner
Apr 19, 2005 01:32 PM
