intermittent rear light failure A6 2.7tdi 05
Old Jul 29, 2013 | 03:46 AM
forsythrce's Avatar
Default intermittent rear light failure A6 2.7tdi 05
over the last couple of weeks warning lamps have indicated first bulb failure then later brake light failure then indicator bulb failure. It happened sometime after starting the car at first but now it comes on quite quickly. I have checked the rear light module connector and bulbs which are ok. I disconnected the module and probed the connector wire terminals where there are 2 earth/ground on the bottom level. One of these, connected to the blue wire, seems to be dead whereas the other shows a small current. When checking the obd2 dtc I get code 2011?? Any ideas please?
Old Aug 14, 2013 | 07:25 PM
CRAZYHAWK's Avatar
I do not understand DTC code 2011.
fyreous
Feb 18, 2010 05:11 PM
zzr
Nov 9, 2009 05:55 AM
MyblackA6
Jul 23, 2009 09:31 PM
Sidewayzracer
May 3, 2009 12:31 PM
CrazyDay
May 13, 2005 02:06 AM
