Looking to buy a 2003 a6
You give very littlle info about the vehicle such as motor -transmission etc. so it is impossible to answer your question.
here are two current threads that you need to read
https://www.audiforums.com/forum/sho...d.php?t=156445
https://www.audiforums.com/forum/sho...d.php?t=156757
Then do a search in this forum and you'll see numerous things you should be aware of -- The most important being the timing belt...
NH USA is correct! I purchased a '02 A6 3.0L knowing that the timing belt had jumped on it, well, the passenger head's camshaft locked up and I'm trying to find a reasonable/affordable head due to neglect on regualr oil changes...
Use caution and ask for service records if available...
PS oil filter was so damn tight, it hasn't been chnged in about a yr or so....
