NEED ADVICE ON 2.7t PLEASE!!
i have bought a 2.7t and since this engine is different than my 3.0l im wondering what basic stuff i should use...
should i continue using 5w30 fully synthetic like i do on my 3.0 or use something diff since its turbocharged?
i live in texas so the climate is very warm.
and any other tips by any 2.7t user is appreciated.
thanks to anyone who helps and thanks for looking
Drive & enjoy!!
UberTeile
If you drive your 2.7T hard, especially during the hot summer months, you could try Mobile1 15w50 - awesome oil for turbo vehicles in hot climates. You WILL see a noticeable difference in your engine temps.
Just make sure that when winter or colder climates come, you change back to a 5W40 or 0W40.
You'll want to change the oil/filter a little more frequently than in the 3.0. I usually change my 2.7T around 7-8k while it's closer to 10k with my 2003 A4 3.0. I'm not sure I would go as high as 15W even in the Texas summer. I believe the specs call for a Mobil1 0W-40 and I would not go over M1 5W-40. You want very viscous oil when it starts so the turbos are well lubed, and then when it gets really hot it should act more as a 40W and not thin out.
