Need help with my VAG-com codes
Old Nov 2, 2006 | 12:22 AM
mikeko's Avatar
Default RE: A good link for removal instructions
Wow!! I wish I would have know to take the wheel and wheel cover out. That would have made my job a lot easier,... when I put the ABS module back on, I will follow the video, which should make my job much easier,... Thanks for the video.
Old Nov 3, 2006 | 02:39 AM
mpw2.7T's Avatar
Default Just be careful when removing the washer tank
There are 3 connectors - 1 for the windshield washer pump, 1 for the headlight washer pump and 1 for the level switch. You'll also likely dump a good bit of the washer fluid. It does make it very easy to get to the ABS module, though.
Old Nov 8, 2006 | 11:21 AM
mikeko's Avatar
Default RE: Just be careful when removing the washer tank
I got my re-built ABS yesterday. Installed it, tested it and it works great!! Total cost $199 ($179 - re-build; $20 - UPS shipping both ways). I highly recommend it for everyone who has ABS problems. mpw2.7T thanks for the link on how to video for ABS removal.
Old Jun 1, 2007 | 02:54 PM
tyleryours's Avatar
where can i find this video ?
Old Jun 1, 2007 | 03:13 PM
techbod's Avatar
last code ???
[IMG]local://upfiles/12092/A51DE37590714672BDB1C0BA97493056.jpg[/IMG]
[IMG]local://upfiles/12092/BC0E21AABCC744F5B7E96E8A94D03A3C.jpg[/IMG]
Old Jun 2, 2007 | 12:51 PM
zymol's Avatar
Where did you send your ABS module for the rebuild? I've never known anyone with succes at having that done that acually lasted. I would like to us them if you are really happy with the work done and it seems to be a good repair..
Old Jun 2, 2007 | 01:10 PM
mpw2.7T's Avatar
Default ModuleMaster......
I follow the forums pretty regularly and I have never seen the first negative comment about them. They provide a warranty on their work and the repair addresses the root cause of the problem, which probably results in better life than buying a new controller with the same flawed design.
Old Jun 4, 2007 | 12:51 AM
  #18
Newport Motorsports's Avatar
Default RE: ModuleMaster......
We use Module Master in ID and have so far been great, and a lot cheaper than new units for our customers. They are quick and effecient.
Old Jun 5, 2007 | 11:32 PM
  #19
toolagit2qwit's Avatar
Attached is ModuleMaster website complete with removal, shipping and Install instructions:
http://www.modulemaster.com/audiabsremoval.html
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
