oxidation removal???
Get a 3M clay bar, not the liquid clay bar product. This will not only remove oxidation it will remove any and all clear coat contaminants. Just use caution when using! Make sure the surface is wet and you will be fine. If the surface is dryyou will rub through the clear, which is obiviously a bad thing. You can use it onall metal painted surfaces, glass (winshield), plastic, and whatever else you can think of.
It's a detailer's secret weapon!
http://www.3mestore.com/60980034767.html?WT.mc_id=3M-com-AtoZ-clay-car-cleaner
Good Luck!
Good Luck!
ORIGINAL: gottwinns
i ended up just wet sanding it with 1200 grit and then i put a clear coat on the headlights so it wouldnt happen again
OOOO
ORIGINAL: gottwinns
[IMG]local://upfiles/51957/C49B3C74A4C6476FB19ACB2AA86D54C2.jpg[/IMG]
