PCV valve question
Old Apr 21, 2009 | 03:27 PM
runamukk's Avatar
Default PCV valve question
I have a 2001 A6 Quattro 2.7t. Does anyone know where the pcv valve is located? Is it easily accessible?Than ks in advance
Old Apr 22, 2009 | 12:05 AM
runamukk's Avatar
anyone?
Old Apr 22, 2009 | 11:51 AM
ppgoal's Avatar
Stock 2002 2.7T with 155K KMs
In recent cold weather the PCV System froze up. Internal crank case pressure went too high causing failure of at least one cam shaft seal. On this particular engine, front crank seal also observed leaking along with both valve cover gaskets and both cam adjuster gaskets. All these seals had been replaced at least once already suggesting PCV problems were brewing for awhile. This engine had the original PCV System and original Oil Cap.
Suggestion for those maintaining a higher mileage 2.7T and esp in colder climates, recommend to replace with updated PCV Spider Hose assembly and updated Oil Cap with internal pressure vent. The cost of maintaining effective 2.7T crankcase ventilation is much less than repeated premature oil seal failures.
If your Audi Engine has a Suction Pump, recommend to replace it along with PCV System. IIRC some early 2.7T engines had a Suction Pump, as well as many 1.8T's and 2.8's among other engines.
YMMV
Here's another picture from another site....maybe it will help. This might be the 4.2 engine.
Old Jun 21, 2009 | 03:43 PM
Xantheon's Avatar
Default That's the 4.2 - and the part I need
So, I figured it was a PCV or CCV but couldn't find any references to the real name or part number for being able to find one. I have a 2000 A8 with the 4.2 and need to replace that part. Anyone know the part number?
Old Jun 22, 2009 | 10:37 AM
chefro's Avatar
Old Jul 16, 2009 | 05:28 AM
N1a6Germ's Avatar
So where is the pcv valve located on the a6 2.7t?!?
Old Aug 25, 2009 | 03:23 PM
N1a6Germ's Avatar
Default PCV valve location
PCV valve is Attached to the F hose and one of the ends off the spider breather hose that runs under the left side of the intake manifold. You need to remove the passenger side Diverter Valve to get to it. Remove the F hose from the breather hose and there it is.
royalcrown
May 19, 2014 12:10 PM
B8tamaster
B8 Models
Apr 22, 2014 10:29 AM
MXZ1983
Jun 16, 2010 09:31 PM
bbbzerk
Mar 21, 2009 11:31 PM
pimphell
Mar 22, 2008 04:19 AM
