power stearing pump or something else?
Old Mar 21, 2009 | 08:04 PM
audirocks's Avatar
Default power stearing pump or something else?
i have a 2000 a6 4.2 and my power stearing does not work from a dead stop or moving slowly ......................... power stearing only works when the rpm goes above 1700.... what can this be? wheres all the experts at?
Old Mar 22, 2009 | 12:38 PM
audirocks's Avatar
someone here must know....... keep them coming!
Old Mar 22, 2009 | 03:59 PM
audirocks's Avatar
keep them coming
Old Mar 23, 2009 | 06:42 AM
bob martin's Avatar
Could be a slipping serpentine belt. Try some belt dressing. If that helps, you need a new belt. If not, your pumps relief valve might be stuck open in which case you need to replace the pump (I don't think you can get just the relief valve).
Bob
Old Mar 23, 2009 | 05:58 PM
audirocks's Avatar
keep them coming.
Old Mar 24, 2009 | 02:53 PM
audirocks's Avatar
anyone?
Old Mar 24, 2009 | 08:18 PM
jeffwantsaaudi's Avatar
Just replaced my ps pump. Check for fluid flow in the reservoir. Your screen may be dirty and restricting flow. The other obvious check is if there is enough fluid. Make sure you use Audi PS fluid. Otherwise you will for sure end up replacing your ps pump.
Old Mar 26, 2009 | 12:59 AM
bzook's Avatar
Did you have to remove the front bumper and lock carrier to change the pump? My pump came in the day after I finished changing the timing belt.
dasos
Dec 8, 2010 10:27 PM
dexx69
May 10, 2010 01:37 PM
audirocks
Mar 18, 2009 03:31 PM
AudiRider818
Nov 12, 2007 02:21 PM
cannon64
Jan 8, 2007 03:39 AM
