power steering leak!!
Old Jan 8, 2008 | 05:41 PM
paaudia6's Avatar
Member
Default power steering leak!!
hello does anyone know the name of the 2 hoses that come from the power steering pump resorvoir i have a leak in my power steering.... when i called the dealer the said one of the hoses was $98.00 is that true or could i get the same part online for cheaper? all help appreciated thanks
Old Jan 8, 2008 | 05:50 PM
auditech79's Avatar
Default RE: power steering leak!!
I doubt you can get those hoses from anywhere else than the dealer. You can try www.shokan.com for some used hoses.
Old Jan 8, 2008 | 06:02 PM
paaudia6's Avatar
Member
are they a pretty reliable parts place audi tech? do u know the name of the 2 hoses?
Old Jan 8, 2008 | 06:08 PM
auditech79's Avatar
Yeah its a great place for used parts. I don't know the names of the hoses, but they are the only two that come off the resivior so it shouldn't be too hard for them to find.
Old Jan 8, 2008 | 06:25 PM
paaudia6's Avatar
Member
cool thanks alot man
Old Jan 9, 2008 | 11:35 AM
MoNaH_a6's Avatar
You should also make sure it is really leaking -
I thought I had a leak, turns out I was a bit low on fluid, it was
sucking some air, foaming up then overflowing.
Old Jan 9, 2008 | 02:21 PM
AZAudiA6Q's Avatar
Germanpartsonline.com has both the suction hose and the return hose for the A6 for cheaper than the dealership is asking.
Old Jan 9, 2008 | 04:58 PM
ne2q 73's Avatar
Clean and dry off the hoses well and check48hrs laterto be certain the leak is only from the hose and not the pump or the steering rack....an expensive part.
Old Jan 9, 2008 | 09:21 PM
catdog's Avatar
ORIGINAL: ne2q 73
What he said.
I'm sure if you have a leak there, it's only one of the two. How did you determine you have a leak?
JT3202
Oct 25, 2012 04:34 PM
CWmovies
May 6, 2012 05:37 PM
salty2113
Feb 26, 2012 01:35 PM
vtraudt
Feb 25, 2012 11:09 AM
