RS6 Build up
Old Mar 25, 2010 | 05:12 PM
jhuffman's Avatar
Default RS6 Build up
So I was thinking the other day about the RS6 being a v8 biturbo. If you were to upgrade to the rs6 turbos would they be slow to spool on the v6? (I can't find much info about them so any info or links would be great!
Also how is the 4.2 in the a6 different than the v8 in the rs6? Would it be possible for a super ambitious person to take the 4.2 block and rebuild it into a biturbo v8 or would it just make more sense to try and find an rs6.
Old Mar 27, 2010 | 06:04 AM
katcoota's Avatar
The topic of adding more power to the 4.2 has been discussed many times here.
It is possible to build up the 4.2 with turbos, but the cost would make it not worthwhile. A better option is to buy the rs6 and that way you get the full package with the bigger brakes etc.
Old Mar 27, 2010 | 01:55 PM
jhuffman's Avatar
I figured as much. Does that mean that the block on the RS6 has reinforced cylinders the same way the 2.7t does?
I still would like some information from anyone who has done the 2.7 turbo upgrade with rs6 turbos instead of the K04s.
Old Mar 29, 2010 | 02:38 PM
WoodShoe's Avatar
Costs 10grand for a supercharger kit that gives the 4.2 same hp as the RS6. Good luck getting an rs6 for only 10g more than a 4.2
Old Mar 29, 2010 | 06:19 PM
auditech79's Avatar
Forget the 4.2L and the RS6. If you already have the 2.7T you can buy garrett eliminators and push over 800 horsepower if you wanted to. Of course you would need to swap out the automatic trans for a manual one and upgrade the gears and clutch. Still that would be cheaper than building a 4.2L/RS6 engine.
Check these bad boys out.
http://www.atpturbo.com/mm5/merchant...egory_Code=27T
These are for the S4, but its the same engine, so you can make it work.
Just saying...
Old Mar 30, 2010 | 01:36 PM
jhuffman's Avatar
Thats a serious set of turbos. I'll have to keep those in mind when I get around to turbo upgrades in the far future. What kind of spool time do you think your looking at with snails that big?
jterranova0
Jan 7, 2020 02:09 AM
Nate01A4
Feb 8, 2014 08:18 PM
rsrbljan
Feb 10, 2008 07:14 PM
onepoint8tee
Nov 7, 2007 10:06 AM
dystynktracing
Jul 31, 2004 11:17 PM
