Total Hose Replacement on Vacuum System
Old Feb 17, 2009 | 09:25 PM
  #21
danmcc86's Avatar
thanks, I found the purge valve for like $70 bucks...but i read on some other threads that the EVAP canister might be bad and cause the valve to jam up...is that so? I dont know, have you heard of that happening? thanks again hxgaser!
Old Feb 18, 2009 | 12:36 AM
  #22
hxgaser's Avatar
Possibly, but I don't know to be honest... If you know for sure that the valve is not clicking away, and you know that it is not the wiring problem. I would just replace the valve itself. As for checking the wiring, refer to this website.
http://vwforum.vwforum.ro/index.php?...post&id=127941
Old Feb 22, 2009 | 02:03 PM
  #23
airportable's Avatar
i have had the same problem with my 99 2.8 not starting after refueling. vag codes were large leak in evap system. repaired with replacement of evap purge valve.$60 from autohaus arizona,hope this helps
Old Feb 27, 2009 | 09:37 PM
  #24
danmcc86's Avatar
Okay, i just got a new PV and when I installed it, it wasn't clicking. So i moved a wire a little and it started clicking for about 30 sec. then stopped. Kinda frustrating...Well, now I'm really thinking its the wiring.
Hxgaser, I looked at the website you gave me and it looks like I need a certain VAG tester...
When should the PV be clicking, all the time?
Is there any way to test the wiring with a multimeter?
Is there any particular spot that the wire might wear through making it ground out?
Thanks, Dan
Old Mar 1, 2009 | 03:59 PM
  #25
danmcc86's Avatar
bump...
Old Mar 2, 2009 | 11:52 AM
  #26
hxgaser's Avatar
Just connect the multi meter from terminal 1 to 2 and you should get 12V when you turn the starter. If you get the valve going by jiggling, it may actually be a bad connector. Do you have a VAGcom?
Old Mar 2, 2009 | 06:19 PM
  #27
danmcc86's Avatar
No, i dont have a VAGcom, although I am planning on getting one. I just have to start making some money first(read: get done with school)
I checked it and it does not have power when i start it up. But when i was checking something else today, I bumped some wiring over there and it kicked on and stayed on. But when i started the car up about an hour later it wouldn't come on. The connection is clean and tight, the fuse is good, so it must be the wiring?
Old Mar 3, 2009 | 12:24 AM
  #28
hxgaser's Avatar
Sounds like wiring to me... but if you have VAGcom, you can test it more specifically. Without it, you are basically playing crap shoot. See if you can isolate the part of wiring that makes difference. Good luck.
Old Apr 23, 2009 | 12:49 PM
  #29
danmcc86's Avatar
Well its been about a month and the purge valve is working just fine. I'm not sure when exactly it started functioning but it is and the CEL is off so... thanks for all the help!
Old Apr 23, 2009 | 01:13 PM
  #30
hxgaser's Avatar
Cool... It is those German electrical gremlins I say.
