Total Hose Replacement on Vacuum System
Hello all,
i replaced my vac lines also , all except the one thats shown as imt valve.
Could not see if I could just pull the vac hose out of it and did not want to
remove the whole assembly in order to take a better look in case I
mess with some alignment of it.
How do you change the vac hose on this?
thanks
Regards
Ted
thanks
Regards
Ted
I had to remove the imt valve itself to replace the hose. Wasn't that bad. Just had to remove the coil assembly. One thing is I dropped a torx bit down under the intake and could not fish it out. As far as I know, it is still there...
redmond1501
May 12, 2014 02:55 PM
