Total Hose Replacement on Vacuum System
Old Apr 24, 2009 | 08:08 AM
  #31
danmcc86's Avatar
Haha...for sure!
Old Apr 27, 2009 | 05:36 PM
  #32
chefro's Avatar
Originally Posted by hxgaser
BTW, if you can replace that entire section of the plastic vacuum line with a long piece of vacuum hose. On mine, the plastic hose was really brittle and broke in numerous places before replaced the entire pipe with a flexible vacuum hose.
HX, thanks a lot man. It was exactly what I was about to ask.
Did you have any trouble at all after replacing the plastic entirely with rubber? Any risk for the rubber ones to clog much faster than the plastic ones?
Old Apr 28, 2009 | 12:21 AM
  #33
hxgaser's Avatar
I had mine like that for about a year and no problem so far... It is just vacuum so shouldn;t clog up. Even if it did, it costs 50 cents and 10 minutes to replace.
Old Apr 28, 2009 | 12:37 AM
  #34
hurricane860's Avatar
same here..just too lazy to fix for some odd reason.
Old Apr 28, 2009 | 11:27 AM
  #35
chefro's Avatar
Tks, bubba.
OReillys suppose to have sillicone ones for like $ 2/foot. I'll just replace all the suckers.
cheers
Old Apr 28, 2009 | 11:31 AM
  #36
james0013's Avatar
You have low fuel pressure and it may be caused by the EVAP purge system. First of all, here is a vacuum diagram.
Basically check the hose from the throttle body to N82 purge valve above the airbox. N82 valve aka EVAP purge valve should click away, and you should be able to hear the noise. If it is working fine, then you should check the large vacuum line running from the valve to the rear of the car, and the related hoses per the diagram.
Also the fuel pressure regulator has a vacuum line going into it. Check that hose as well.
Anyone know how different this would be for a 2.7t
Old Apr 28, 2009 | 08:29 PM
  #37
danmcc86's Avatar
this diagram is found under the hood of (i think) all Audi's. its in the bottom right corner...
Old Apr 28, 2009 | 10:35 PM
  #38
a2thy's Avatar
Anyone whos already done this mod, how long did it take you? I'm about to do it with my 1.8t, but I'm guessing mine will have more hoses than a 2.8.
Old Apr 29, 2009 | 11:01 AM
  #39
danmcc86's Avatar
It took me about an hour and a half. There was very little dismantling. The hoses I took off of my car were crumbly messes so replacing them is a good thing to do and easy too!
Old Apr 29, 2009 | 12:43 PM
  #40
NH_USA's Avatar
You saved a bunch of dollars by doing it yourself --- Our local dealer costs an even $100 per hour and would have used Genuine Audi Replacement Parts instead of generaic vacuum hose - the major difference being the packaging - I estimate you saved about $300 and had a lot of fun cuddling your Audi.
