towing with an A6
Old May 16, 2007 | 10:37 PM
plusinfinit's Avatar
Default towing with an A6
Was just wondering what the maximum weight is anyone here towed with their A6 QUATTRO?
I have a 99 2.8 a6 avant quattro automaticand towed a broken ford explorer 2 door up a steep hill to a parking lot. Kept it in first gear and under 2300 RPM. car did just fine. Was towing only for 300 feet or so but i am impressed at the ease at which it towed that explorer.
Plan on puting a hithc for a utility\motorcycle trailer, anyone has experince with that? How does the car handle under load? how much can you actually tow 1800lbs or so?
Old May 17, 2007 | 03:19 PM
lubes17319's Avatar
Default RE: towing with an A6
Just pulled a 4'x8' Uhaul trailer loaded to the brim with my '95 A6Q, which was also loaded with all my belongings 1/2 way across the country...from NC to Denver.
Nervous the entire drive, but no problems at all. 97.395% on the highway, so no issues for the trannie.
Wouldn't recommend doing anyslalom courses while hauling your junk, otherwise it should handle nice when loaded. 70mph +/- pretty much the whole way, and it felt niiiice.
My bro pulls his dirt bikes on his trailer (w/a 2002 Legacy GT) with no probs, but he said an Al frametrailer is a must for constant use - 300# or so empty.
Old May 17, 2007 | 06:51 PM
ppgoal's Avatar
The guy I bought my A6 from towed a small trailer frequently to trade shows. I would estimate an enclosed trailer about 8' long. The reason he was selling the car is that he had to start hauling a much larger trailer. The car had 36k miles on it and everything was fine. I did note that he had brakes done around 40k which seems a little early, but I do a lot of highway driving and with a 6-speed, don't use the brakes a lot. I did have to replace the clutch and flywheel at 89k, but I think it was due more to the extra power caused by chipping it 10,000 miles earlier.
I have no idea where he found the hitch, but it is a small one. It looks like it takes a 1" ball assembly rather than the 1.5-2" ones I see on full size SUVs. Obviously I've never used it.
Old May 18, 2007 | 12:07 AM
prbayha's Avatar
The car is completely capable of towing a motorcycle trailer and gear. I have a trailer set-up with a YZ 125 and a YZ 85R and although I pull it with my truck, the whole things weighs around 1200 lbs. I pull it with a 4 cyl 2 wheel drive. Its not even there. The only thing I would be worried about is an overweight load and the added stress to AWD system on hills/steep grades. Brakes will also wear quicker but if you take it slow and keep it under 1500lbs, you have absolutely nothing to worry about.
Laconia A8L
Jun 26, 2018 02:54 PM
dpwct
Sep 6, 2014 10:14 AM
griffman
Audi Q7
Sep 24, 2010 05:33 PM
djMichaels
Mar 18, 2010 09:11 PM
