Tranny issue 2001 A6 2.8 tiptronic
Old Jan 28, 2012 | 01:29 PM
azaudia6's Avatar
Default Tranny issue 2001 A6 2.8 tiptronic
Just purchased an 2001 a6 fwd w/ 115k. Transmission shifts into 2nd gear and runs up to 4000 rpm and then does not want to shift into 3rd. something just doesn't seem right. will shift great in tiptronic mode. My friend is a mechanic and says it might just be the shifter. It doesn't do it all the time either. it's hit and miss.
Old Jan 28, 2012 | 08:52 PM
Jackmup's Avatar
There is an aftermarket flash for this
Mine stutters in 2nd
It is a ECM or tcm issue if tip works
Old Feb 1, 2012 | 06:02 PM
EEZYMONEY29's Avatar
My 2001 2.8 a6 quattro is doing the same exact thing. So it's an ECM or TCM issue?
Old Feb 1, 2012 | 07:46 PM
Tourbo24's Avatar
my tranny didnt want to shift at low RPM going from 3rd-4th and 4th-5th, I also had a bad coolant temp sensor. I guess the sensor was telling the car that it was still cold and that it should shift up at 3k rpm instead of the usual 2k rpm. Replacing the sensor solved my issue. Just wanted to put this out there, maybe you got a bad sensor too?
cboltin5
Sep 3, 2014 02:10 PM
a4coni
Sep 4, 2011 06:57 AM
twilliams83
Nov 16, 2010 10:17 PM
carguyno1
Oct 24, 2008 11:22 PM
Audi_Skydiver
Apr 1, 2007 08:29 PM
