Transmission Question
My transmission sometimes jerks i believe when its chaning gears while accelarating or decreasing speeds...when i accelerate from a dead stop i have no problems it goes trough the gears smoothly....this jerking only happens when i let off the gas and then immediately give it gas then it seems to make that jerk and that noise like when u let off a clutch fast on a manual transmission...does this sound like a problem?
Could it be an engine or transmission mount? The engine lifts up when you give it gas, it falls when you let off the gas quickly? My 9k again did this as well, not sure if this is what you are describing though. Just a guess though.
Jeff
Jeff
Yes it feels like something dropss and u can hear it...i realized this when i was driving last night btw 50-80mph..if i give it gas and let off it feels like something drops...but it doesnt do it all the time...i dont know the transmission behaves normal to me...from a dead stop if i accelerate normally it goes trough the gears just fine no slipping no sounds nothing what so ever...that is the only thing that i have realized and i hope its not my transmission...should the computer generate a code for me if something is wrong in the transmission???
Your transmission will set a code if there is a problem. There may very well be instances where this does not happen, but I am pretty confident you need some sort of engine or transmission mount. It will not bang around all that much if the mounts are not that bad while just accellerating normally from a stop. They make the most amount of noise when you torque the engine, let off the gas and then torque again. Something like that.
Jeff
Jeff
I have the same exact problem on my 99 A4 w/ 77k on it. I truly feel it's either the trans or engine mount. I think we are experiencing the famous driveline shock people experience when letting off the gas. This is the result of eccessive movement in thedrivetrain (relationship between drivetrain reaction to engine response) that should be absorbed by the mounts. I think the snub mount that most people install should take care of this issue. I will soonbe installing one myself to hopefully fix this same issue.
