Transmission slipping?
Old May 23, 2008 | 10:11 AM
NH_USA's Avatar
Default RE: Transmission slipping?
gubro30 has it correct.... 2 seperate problems
Thick white stuff in the water is called Mayonaise and is the result of oil and water being mixed. -This is a big problem! Do you see the same thing when you pull the dip stick? If yes don't drive the car because your using water to lubricate the bearing - a very bad thing - If no you need to find out how the oil is getting into the water - 90% chance it is the head gasket -
Transmission oil / seals is a seperate problem and could easily cause the slippage your describing.
I can't tell you how much it will cost - but find a good indy and bring money - lots of money!
Maybe some can stear you to a good indy in your area.
Old May 26, 2008 | 11:45 PM
a6hcw's Avatar
Cars with automatic transmissions usually have a transmission cooler in the radiator, which may fail. When this happens, ATF will leak in to the coolant and coolant will leak in to the ATF. Since Audi doesn't have a transmission dip stick, this may go unnoticed and lead to transmissionfailure.
Old May 27, 2008 | 07:31 PM
tdblanchard's Avatar
i bought a CPO 2005 A6 and it seems to have the same symptoms..
Do you think this would be covered under the CPO warranty?
Also, we were driving on the road (10+ hours) and towards the end, the car just shut down twice as if it was out of gas....
Any ideas?
wglipscomb
Mar 25, 2015 12:22 PM
ceroberts75
Sep 2, 2012 11:56 PM
PhilipM
Aug 29, 2012 11:51 PM
Porter50
May 5, 2009 11:43 PM
steveneashcraft
Dec 7, 2007 11:29 PM
