upper control arms
need some help i need to replace front upper control arm ,,it looks like the whole strut and both arms assy need to be removed ,otherwise the bolt will hit the inner fender area ,,bently manual didn't show much ,any help would be great thanks
There easy to do, remove the upper bolts on the strut under the hood, then remove the bolt holding the upper links to the steering arm and bang the links out with a hammer or something cause they get stuck, then remove the 16mm nut for the tie rod end at the steering arm and bang it out, the last bolt would be the bottom strut bolt (18mm) loosen but do not remove it, pull down the strut and swing it towards you out of the fender you don't even have to remove the strut from the car then replace the links one by one. Make sure to place the new links exactly where they were tensioned before so you don't prematurely wear them out.
Install them in reverse order, i usually use a jack under the brake rotor to push the assembly upwards to line up the bolts for the top of the strut, good luck.
thanks auditech79 i just replaced both tie rod ends and after the first one the second one was a breeze ,after looking under the car i kind of had an idea ,but wanted to make sure ,,should be easy on the lift i just installed .
In my case, i suspected a trouble to my control arm but a mechanic told me that i needed an audi strut and that the noise is comming from the strut mount.
jdahlen24
Aug 25, 2011 03:05 PM
