Sponsored by:
Sponsored by:
valve gasket in INDY
Old 02-04-2008, 08:39 PM
jcyj2's Avatar
Default valve gasket in INDY
Hello folks~
I went to Indy mechanic for changing a valve gasket. And the mechanic said I need to change the cover gasket as well
as valve gasket.
I have no idea what the differencesare between gasket & cover. Of course they charge laborof two jobs.
Somebody has an idea? Thanks.
Old 02-04-2008, 09:32 PM
auditech79's Avatar
Default RE: valve gasket in INDY
I don't know what this mechanic is trying to do to you but there is ONLY a valve cover gasket and cam adjuster seals under the valve cover.
The valve cover comes with the center part that goes around the spark plug holes.
Look up a picture of it on www.ecstuning.com
Old 02-05-2008, 09:09 PM
jcyj2's Avatar
O ring is also one of the valve cover gasket?
mechanic said need some special tool to change the o ring
he is su**s
Old 02-05-2008, 11:33 PM
auditech79's Avatar
There is only the valve cover gasket, and half moon cam seal which requires a special tool to get at. If he's talking about the cam seal then he is correct.
9a49
10-13-2009 09:26 PM
robert.jones
12-10-2008 08:01 AM
robert.jones
12-10-2008 07:56 AM
fcanozo
11-07-2007 02:57 PM
lgbyblock
04-29-2007 09:43 PM
Quick Reply: valve gasket in INDY
