Vanishing Antifreeze
Old Aug 24, 2007 | 12:09 PM
MiniSpdRcr's Avatar
Default RE: Vanishing Antifreeze
What could be the problem under the plenum...and what do you mean by that? Also, where does that hose connect to? Isit bad to drive it like that?
And it seems that the Antifreeze leak sort of slowed down...its weird...I am not loosing it as much.
Old Aug 24, 2007 | 12:13 PM
techbod's Avatar
the coolant pipes on the v6 run under the pentium and very common for leaks due to expansion of the clip/clamp or hardened pipes
Old Aug 24, 2007 | 01:26 PM
MiniSpdRcr's Avatar
Great thank you.I will check it out tonight. Also, would you happen to know where that breather hose would connect to?
Old Aug 24, 2007 | 10:57 PM
auditech79's Avatar
ORIGINAL: MiniSpdRcr
I think they connect to the back of the head, check the other cylinder head and see where that one is hooked up to.
Tullybeagles
Dec 7, 2010 03:37 PM
sljone
Aug 24, 2009 04:35 PM
anmagro
Nov 3, 2008 10:42 AM
ballswell
Nov 26, 2007 02:29 PM
blast
Mar 12, 2005 11:20 PM
