washer fluid leaking. Any idea ?
It commonly breaks off at the fitting on the washer pumps, take the belly pan off and you can see both the headlight washer pump and windshild pump. It will be either that or a plastic connector fitting.
It is fairly common for the headlight washer pump to crack and leak. Poor design of the pump body. The quality of the replacement pump is better. Search on AudiWorld for the techarticle on how to replace that pump. About a $20 part and all you need are some common tools and you can DIY.
where did u found it?
Hmm, i cant find anything, about how to repar pump at http://www.audiworld.com/tech/
Stearnsy
May 5, 2013 06:12 PM
