washer fluid leaking. Any idea ?
Old May 12, 2007 | 11:48 PM
vrso2's Avatar
Default washer fluid leaking. Any idea ?
Hmm, thats happend two weeks ago. I just loosing washer fluid, but i dont know, where from.
'99 2.8 quattro
Old May 12, 2007 | 11:51 PM
Jeffla's Avatar
Default RE: washer fluid leaking. Any idea ?
Mine leaks from the headlight washers.
Old May 12, 2007 | 11:57 PM
vrso2's Avatar
But leaking, when i do not use washer.
Old May 13, 2007 | 12:10 AM
auditech79's Avatar
It commonly breaks off at the fitting on the washer pumps, take the belly pan off and you can see both the headlight washer pump and windshild pump. It will be either that or a plastic connector fitting.
Old May 13, 2007 | 12:22 AM
Boston Driver's Avatar
It is fairly common for the headlight washer pump to crack and leak. Poor design of the pump body. The quality of the replacement pump is better. Search on AudiWorld for the techarticle on how to replace that pump. About a $20 part and all you need are some common tools and you can DIY.
Old May 13, 2007 | 10:09 AM
jj2345's Avatar
my 99 a6 was also leaking washer fluid,so i checked it out and itwas only a loose clamp,so i bought some new clamps and the problem was gone
Old May 13, 2007 | 05:07 PM
vrso2's Avatar
where did u found it?
Hmm, i cant find anything, about how to repar pump at http://www.audiworld.com/tech/
Stearnsy
May 5, 2013 06:12 PM
loyolacub68
Aug 23, 2011 06:00 PM
TheDavey
Apr 2, 2009 11:44 PM
chief
May 22, 2008 02:37 PM
apg96
Jun 28, 2006 03:41 PM
