weird noises...
Old Aug 9, 2006 | 02:04 AM
ReX's Avatar
ReX
Default weird noises...
so i get this weird noise when im going relatively slow
and when i turn my steering wheel... i dunn really know how
to describe the noise.. it sounds kinda like metal rubbing on
something... anyone have any similar problems?
Old Aug 9, 2006 | 11:19 AM
DMC's Avatar
DMC
Default RE: weird noises...
Yes, my 05 had the same symptom. Was the Power Steering pump almost out of fluid. They eventually found a leak in the system and repaired. If that's what it is, DO NOT use just any fluid, you must use Audi approved Mineral Fluid, something your local Target won't have.
Old Aug 11, 2006 | 10:57 PM
dankhound's Avatar
A creaking/squeaking noise is most likey a bad outer tie rod end. More of a knocking or ticking is probably a cv joint. Dont overlook the above metionned oil fluid issue thou.
mcclendonthaboss
Jul 27, 2009 05:22 PM
AUDI_DAN
Sep 2, 2008 06:39 AM
hyperlight900
Sep 19, 2007 04:05 PM
chaos92287
Nov 14, 2006 04:03 PM
a4crazy
May 24, 2006 09:11 PM
