Window & hazard light issue
Old Oct 20, 2015 | 10:19 PM
john62's Avatar
Default Window & hazard light issue
I am a new owner of a 2001 A6 Quattro 2.7 The windows will not roll up or down, the sunroof will not go back and forth, the inner lights and locks do not work. They all went out at the same time. The radio, air, auto heated seats still work and everything on the outside works & the hazard lights come on for no reason. Fuse 14 (10 amp) is blown When I replaced it the lights worked but the fuse blew again. Thank you for any help.
Old Oct 21, 2015 | 05:56 PM
john62's Avatar
Default Update
After reading others problems with this I took the carpet up to check the harness the black box under the drivers seat that hold what I think is the ICU was holding a lot of water. I will see is I can add a picture.
Old Oct 22, 2015 | 10:14 AM
john62's Avatar
Default Photo Update
THis is what I took out from the drives seat that had a lot of water in it. Is the icu or ecu? If I buy one from ebay do I have to program/recode it? Please help
Old Oct 22, 2015 | 04:39 PM
saifxnyc's Avatar
try audi world people rarely respond here... forums.audiworld someone might be able to help you out
A6 / S6 (C5 Platform) Discussion - AudiWorld Forums
Old Oct 25, 2015 | 10:21 AM
john62's Avatar
Problem solved
Old Oct 28, 2015 | 12:51 PM
saifxnyc's Avatar
Originally Posted by john62
Problem solved
What solved your problem
Old Oct 30, 2015 | 09:47 PM
john62's Avatar
replaced the icu
Mr.Gerb1k
Sep 28, 2013 11:00 PM
karty08
Aug 14, 2013 02:08 AM
myaudia4
Aug 20, 2005 12:34 PM
