96 A8 4.2 not starting.
Old Jul 28, 2006 | 07:39 AM
elginedition's Avatar
Default 96 A8 4.2 not starting.
hi to you all, this is me first time on this forum, and looks really well sorted.
i'm just wondering if anybody has had this starting problem the car turns over, sparks, and the fuel pump buzzes, the fuel filter is new as well, their's fuel at the injector rail and pressure, the car wants to start but dies off. the batterry is new and i've had the car plugged into the vag 1551 diag machine which comes up with no fault codes at all. its really cheesing me off now as i havn't driven the car for nearly two months, any suggestions would be welcome, and it does have half a tank of petrol in it before anyone says the obvious.
i am suspecting the fuel pump but want to explore all cheaper options first.
Old Jul 28, 2006 | 09:26 AM
techbod's Avatar
Default RE: 96 A8 4.2 not starting.
do you get any fuel to the plugs?? the injectors might not be working, check for power to them you can use a multi meter or noid light
Old Jul 28, 2006 | 04:01 PM
i've had the fuel pump out, and tested it (puts out over 2bar) , i've replaced the 4 bar pressure regulator, and the fuel filter. it does spark and the plugs are wet.
the only reason i thinks its the fuel pump, is that when i took it out and tried it, it worked, i then fitted it back to the car and the car started and only idled for a while, it didn't respond to the throttle very much then proceeded to cut out, and wouldn't start again.
Old Jul 28, 2006 | 05:38 PM
tonypai's Avatar
What year is your car? I sounds like the immobilizer.
Oh, never mind. I don't think the 96s came with an immobilizer.
Old Oct 3, 2009 | 10:12 AM
reagd's Avatar
yeah this is correct, to check if there is a voltage going to the fuel injector, a noid light should be used.
Old Oct 3, 2009 | 06:46 PM
AWDaholic's Avatar
Senior Administrator
you realize this is a 3-year-old thread, right?
Old Oct 3, 2009 | 10:45 PM
auditech79's Avatar
Yeah, now who looks like the dumb *** LOL.
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
