A8L microphone not working
Old May 9, 2015 | 02:47 PM
JR2006's Avatar
Default A8L microphone not working
Hello I am new to the forum and the Audi A8L. I am look for some help in determining why my microphone does not seem to work.
Can any one post a print out from VCDS / Advanced ID from a working voice command system. modules 67 voice command and 07 head unit Mine are below 2006 A8L I found a post that these must be at the same SW: revision for the Voice command system to work.
I have no error codes and all coding matches posted scans from working systems I have been able to find. Just looking to confirm or eliminate software revision as one possible cause.
1) Can Make calls
2) Can receive calls
3) Can here a caller
4) No one can hear me ( checked Microphone is not muted )
5) PTT button on wheel shows inactive when pressed but shows good in VCDS test.
6) MMI is running SW: 4610
My test seem to show SW not at the same revision but new to VCDS and do not know if highlighted in red is the numbers to compare.
Thanks for any help
will be looking at a timing belt change as I just hit 75K but seems similar to my 2002 VW Passat 2.8 V6
wanted to start and work through something simple or NOT as this is proving to be first.
__________________________________________________
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303EE067522360
Coding: 0000003
Shop #: WSC 08599 002 1048576
VCID: B22852A82D12AEB128B-80E7
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000003360
Subsystem 3 - Serial number: 0117.03.060000000100010038ÿ
Subsystem 4 - Serial number: 010038ÿ
No fault code found.
__________________________________________________ ___
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000907090290
Shop #: WSC 12336 024 394758
VCID: B42454B0D706A0813A7-80E1
__________________________________________________ _____
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007531867
Coding: 0010900
Shop #: WSC 02313 785 00200
VCID: A208A2E87DF23E31D8B-80F7
__________________________________________________ __________
ADVANCED CHECKS
Address 16: Steering wheel (4E0 910 549 )
19:28:41
Not Oper. Blinker
Not Oper. Multi-Function Button (Left)
Activated Multi-Function Button (Right)
Not Oper. Thumb Wheel (Left)
Not Oper. Thumb Wheel (Right)
__________________________________________________ __________________
Control Module Part Number: 4E0 910 732 S
Component and/or Version: Interfacebox H43 4610
Software Coding: 0000003
Work Shop Code: WSC 08599
VCID: 3228D2A8AD122EB1A8B-8067
Additional Info: 4E0910611 E0380 BedienteilH03 0040
Additional Info: Geraet 1048576
Advanced Identification
Identification: JTB-003
Revision: 00000000
Date: 14.02.13
Test stand number: 0002
Manufacturer number: 1340
Identification: PRE-001
Revision: 00000001
Date: 17.03.06
Test stand number: 0001
Manufacturer number: 0038
Software
X4610
M010911
M0200
X040000/051108103425
X05421AFC6AB320040
Misc.
Hardware number: 4E0 035 729
VCDS Info:
Address 47: Sound System
Control Module Part Number: 4E0 910 223 K
Component and/or Version: DSP-Amp.-High H13 0440
Software Coding: 0000016
Work Shop Code: WSC 02313
VCID: 250239F4ECDC49093D9-8070
Serial number: 00000000007384
Identification: RSU-001
Revision: PROD_01
Date: 06.02.06
Test stand number: 0000
Manufacturer number: 7384
Software
X01.17.80-24.08.2004-06.21-44
M01.09.11
M02.04.02
Misc.
Hardware number: 4E0 035 223 A
VCDS Info:
Labels: 4E0-910-223.lbl
Control Module Part Number: 4E0 910 754 Q
Component and/or Version: SDS 3501 US H46 0630
Software Coding:
Work Shop Code: WSC 12336
VCID: 3424D4B057062081BA7-8061
Identification: TFU-030
Revision: 00000000
Date: 09.07.09
Manufacturer number: 0290
Software
X0630
XUS119
M2.00
M010911
Misc.
Hardware number: 4E0 035 753 A
VCDS Info:
azzy28
Jan 29, 2012 11:03 AM
Nellyuk
Nov 5, 2011 12:48 PM
Gully
Aug 24, 2011 05:10 PM
S4B6Dave
Feb 5, 2008 10:00 AM
AndyA4C
Oct 21, 2006 11:48 PM
