Audi A8 transmission problems
Old Apr 29, 2009 | 07:37 PM
auditech79's Avatar
Originally Posted by AudiA8Quattro
Are there any additives that are ok to use to stop the leak?
There does seem to be a lot of oil higher up on the head, but it is hard to see because all the piping. I will probably remove the throttle body at some point so i can get a better look. Can the auto trans fluid leak that high up?
The leak isn't fast as i can actually see it dripping out, but if i go for say a 5-10 mile drive, there is oil on the subframe again. It is coming off the undertray and ending up on the n/s cat converter. The converter actually smokes with the amount of oil on it! Is this likely to cook the converter?
Can you tell me what sensors are on the back off the head? i'd still like to check them out.
If the seal had gone on the torque converter, is just a new seal needed or will i need to change the torque converter?
Cheers.
Well i actually think you may have multiple problems here, trans fluid can't get up on the cats, that would be an oil leak from the valve covers. Thats not a very big deal besides smelling burnt oil. Thats common on almost all audi V engines. I would be more worried about the trans like crazyeights said, and have a transmission specialist give it a thorough examination. We can fix the oil leaks later.
Edit: Oh and you're cat conveters aren't in any danger by having oil leaking on them. Just stinks and smokes.
Old Apr 30, 2009 | 07:07 PM
AudiA8Quattro's Avatar
I'm still not convinced the transmission is leaking. The oil leak does look like its coming from higher up, but the valve does look ok. The cam sender on the left hand head (looking from the front of the car) has got a leak, but all the oil is gathering on the other side on the subframe. Using a the inspection mirror, there does seem to be a load of oil on the back of the right hand head, but its still too difficult to get a really good look.
The oil seems to be coming off the subframe and ending up on the n/s cat converter when i drive.
As i said before, are there any sensors on the back of right hand head, excluding the cam sender, that may leak oil?
Cheers.
Old May 1, 2009 | 10:45 AM
auditech79's Avatar
Nope, just valve cover gaskets and cam adjuster seals.
Old Oct 5, 2011 | 10:16 PM
jack landry's Avatar
Default 1999 a8 quatro
i had tranny replaced a month ago.twice leaving stop sign,all lights come on (p,r,n,d,1,2,3)turn car off & restart everything o k any ideas?
Old Oct 30, 2011 | 08:20 AM
Nollywood's Avatar
The most common areas the ZF tranny leaks oil from are:
01) Torque converter oil seal (needs tranny pull to fix).
02) Prop shaft output flange seal on rear of tranny (needs prop and output flange removal to fix).
03) Passenger side axle shaft output flange seal (needs axle and output flange removal to fix).
04) Driver's side axle shaft output flange seal (needs axle and output flange removal to fix).
Old Oct 30, 2011 | 08:23 AM
Nollywood's Avatar
Possibly wrong fluid level, faulty F switch, other internal fault. Best option is to get her VAGCOM'd, that way you'll know what's wrong for sure.
Old Oct 30, 2011 | 10:17 AM
silverd2's Avatar
Maybe no help, but a clarification:
#1 is a trans leak...atf
#'s 2, 3 & 4 are differential leaks...75/90 gear oil...all replaceable with trans installed and nothing whatever to do with any trans problems or symptoms.
Old Oct 30, 2011 | 10:19 AM
  #18
silverd2's Avatar
...or rain water intrusion (common) or resulting electrical connection corrosion in the electronics box (ECM & TCM in there) in the plenum under the hood.
Old Oct 31, 2011 | 02:44 PM
  #19
Nollywood's Avatar
You're dead right, every bit of info on the ZF tranny is a great help.
I'm no auto trans fan, hence my decision to convert my own car to 01E 6-speed manual, before something in the ZF goes bang.
Ormándi
Jun 2, 2014 01:41 PM
Ay Zeus
Jun 16, 2011 09:56 AM
Blissra
B8 Models
Jan 15, 2011 12:00 PM
balla915
Sep 27, 2009 08:24 PM
gaulin99
Jul 24, 2007 04:56 PM
