Changing oil in 4.2L
Old Mar 12, 2014 | 11:47 AM
ex56TT's Avatar
Banned
Default Changing oil in 4.2L
1. what kind of oil do you use ?
2. my plastic cap is cracked, i am getting this bad boy Do you guys use any anti seize on the thread ?
Billet VW/Audi 4.2L V8 Oil Filter Housings !
Special Pricing in Effect ! Precision Machined Aluminum Oil Filter Housings For VW And Audi 4.2L V8 Engines !
GruvenParts.com now has these billet aluminum oil filter housing covers for VW and Audi 4.2L V8 to replace OEM part number 077-115-433B (077115433B). The OEM plastic oil filter housing cover is not very durable and often strips out making it impossible to remove the oil filter. The engine flange which this cover screws into costs over $1,000 and is easily broken while trying to remove a stripped filter housing cover. We have put an end to this nonsense !
The GruvenParts billet aluminum oil filter housing cover is made from a massive chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed onto one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal. It simply doesn’t get better than this!
We also provide USEABLE 24mm hex flats so you can easily remove the housing with a standard 24mm socket. This could possibly make changing your oil fun again!
Fits the following vehicles :
VW Phaeton w/4.2L V8 (all years)
Audi A4/S4/Quattro/Cabrio (2002-2007) w/4.2L V8 BHF engine
Audi A6 / AllRoad (2001-2007) w/4.2L V8 BNK and BAS engines
Audi A8 (2003-2006) w/4.2L V8 BFM and BGK engines
May fit other vehicles as well, please check to see if your vehicle uses OEM part number 077-115-433B (077115433B) oil filter housing cover.
This housing uses the standard OEM filter, P/N 079-198-405A (079198405A). You can order the billet housing with or without the filter.
Old Mar 13, 2014 | 03:47 PM
ex56TT's Avatar
Banned
bump for this question
Old Mar 14, 2014 | 08:47 AM
dirtydub01's Avatar
I always use Pentosin 5w40 full synth. I also use the ECS billet oil filter cap with no anti-seize in place of my stripped OEM cap. Love it! And for the ECS cap all you need is a 19mm socket (same as stock I believe). Not sure why Gruven uses a 24mm...
madridlover
Jul 2, 2012 01:44 PM
raudi28
Aug 17, 2011 02:13 AM
Booney1.8
Feb 7, 2008 01:27 PM
JOnJOn
Feb 6, 2008 11:41 PM
ZedEx
Dec 21, 2005 03:39 AM
