Front Air Suspension
Old Sep 9, 2012 | 03:17 AM
Warold's Avatar
Default Front Air Suspension
Gents,
I have a problem with my 2004 A8.. Recently after leaving the car sleeping for the night I come back to find both my front shocks have deflated. I start the car and they pump back up to normal position.
My questions are, is there something electrical that can make the shocks deflate, as both fronts have done it. I have scanned for codes but nothing. Also it takes a while for it to deflate. I mean 10 hours +, Is the compessor supposed to top up the shocks as they lose some air?
Could it really be that I blew both front shocks at the same time?
Thanks in Advance
Old Sep 9, 2012 | 08:24 AM
jakematic's Avatar
The vehicle will auto-level after locking - that's the "hiss" you hear.
Otherwise no, it should not deflate and settle overnight.
The compressor will not run when the engine is off.
When you say codes, you mean scanned with VCDS (formerly VAG-COM) ?
My thought is that it is a slow leak from an air line.
Could be both shocks are blown - unlikely but I've seen stranger things over the years
Over time you will likely see DTC's with VCDS like compressor overheat.
Then at some point the relay could get fused.
Hopefully it's just a minor leak in a line that you can find with soapy water and a good ear in a quiet place.
Old Sep 9, 2012 | 03:05 PM
Warold's Avatar
Thanks for the reply,
My question is, are there individual air lines leading from the compressor to the shocks? or are the front shocks interconnected so that if there was a leak, it would lead to both fronts sleeping.
Old Sep 10, 2012 | 09:59 AM
grease's Avatar
individual air lines from a control unit to each shock. If you have a leak on one spring the computer will bring the other spring level down to compensate and keep the ride equal on one axle.
screener
Feb 21, 2010 05:27 PM
4 Petes Sake
Apr 18, 2009 01:18 AM
Bravo8807
Oct 23, 2008 12:29 PM
wildlife9000
Jun 1, 2007 04:35 PM
