Water leak into passenger floor
Old Jun 7, 2006 | 07:59 PM
Iceman9100's Avatar
Default RE: Water leak into passenger floor
I called an Audi advocate today to find out if there was a way to prevent the backup/blockages from happening he suggested the I use womens stockings/nylons to cover each of the drainage ports. This would stop the leaves from getting in the tube and prevent blockages. I think it is a darling idea. Any thoughts? He called the local dealer to find out if that is considered altering the design and they said yes. So I said I will take the nylons off before I take the car to the dealer.
Old Jun 8, 2006 | 12:15 AM
rmarciano's Avatar
Apparently the mechanic altered my drainage ports. I will have th car tomorrow, but from what I understood, he cut the ends that have those paperthin slits- as he said, a spiderweb would clog them. As for the two drains in the center, he is opening them and feels that should solve the problem. I'll get the bill for the hot water circulator tomorrow. Anyone know what repalcing front brake pads and rotors should cost?
Old Jun 8, 2006 | 04:17 AM
Propagandalf's Avatar
Have a similair problem with my A6. Except it wasnt a blocked drain, it was a mis-installed batter cover that was directing water into the AC intake. Clean that water up pronto, I am staring down massive electrical gremlins due to saturated control modules under the seat.....
Old Jun 10, 2006 | 10:16 AM
rmarciano's Avatar
Just spent $2,500 correcting my water problems. Audi does not stand behind a single thing. There are drainage 4 ports-- one at the rear of each front wheel(you can reach it without a lift or taking the wheel off) and two below the fresh air intake and above the tranny I believe. These are the problems and difficult to clear. they get clogged very easily and then the cowel beocmes a pool and all of your wires and in my case the hot water circulator($1,400) are ruined. You need to clear all of the drainage prots regularly.
Old Jun 12, 2006 | 12:50 PM
Iceman9100's Avatar
That sucks bro 2500 dollars. If your car is still under warranty have your local dealer call the district to get approval to fix the problem.
RoadsterJohnny
Feb 20, 2018 02:51 PM
asrod2007
Audi Q7
Oct 10, 2014 12:32 AM
hdieffenthaller@gmail.com
Aug 6, 2010 02:06 PM
kevin1533
Aug 18, 2008 01:18 AM
