Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
Check Engine Light
Old Dec 26, 2022 | 12:48 AM
anon1m0us's Avatar
Default Check Engine Light
I ran VCDS and it came up with the following codes:
7 Faults Found:
5393 - Engine Mount Solenoid Valves (N144/N145)
P1586 00 [044] - Short to Plus
21501 - Engine Coolant Temperature Sensor 3
P01E3 00 [175] - Electrical Malfunction
8863 - Diesel Particulate Filter
P2459 00 [096] - Regeneration Frequency
13156 - EGR Temperature Sensor 1
P040B 00 [104] - Implausible Signal
25301 - EGR Temperature Sensor 1
P040B 00 [236] - Implausible Signal
18173 - Exhaust Gas Recirculation Cooler Bypass Control Circuit
P245B 00 [237] - Implausible Signal
19406 - Exhaust Gas Recirculation Cooler Bypass Control Circuit
P245B 00 [096] - Implausible Signal
[Exhaust Gas Recirculation Cooler Bypass ControlCircuit Range/Performance]
I want to address is the Temp sensor. Which sensor is it? Where it is located? WHat part do I need to order?
Juliet
Oct 30, 2012 02:53 PM
punjabi
Jul 7, 2010 02:55 PM
tj19855
Jul 2, 2008 09:04 AM
tj19855
Jul 1, 2008 06:33 PM
jasgtr
Jan 22, 2008 12:30 PM
