1.8T to 2.0T + K04 Turbo upgrade
Old Feb 5, 2008 | 04:07 PM
Red_sapphire89's Avatar
Default RE: 1.8T to 2.0T + K04 Turbo upgrade
so the aeb head will match up the stock pistons etc and the intake manifold? or not
Old Feb 5, 2008 | 04:16 PM
the VVT 225 TT makes 396hp and 360 foot-pounds of torque on 93 octane pump gas at the flywheel.. so thats like 350awp
Old Feb 5, 2008 | 04:19 PM
cincyTT's Avatar
I'm make believe
The head only changes what intake manifold you run. All other 1.8t's use a small port head and manifold. When going to a big port head you need to go with a big port manifold. These have shown 25-50whp gains depending on turbo and manifold used (atleast a gt2871r or larger). If you install a head and cant afford a manifold at the time, 034motorsports sells a transition gasket to help keep flow from becoming turbulent untill you can install a big port manifold.
Old Feb 5, 2008 | 04:20 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: Red_sapphire89
The most i have seen is 320awhp on a dynojet (which read higher than others)
Old Feb 5, 2008 | 04:26 PM
hmmm whats a 100% stock tt 225 awhp like 175ish?
Old Feb 5, 2008 | 04:32 PM
cincyTT's Avatar
I'm make believe
wishiwasRWD dynoed 190whp, but that was done in fwd (disabled the rears). Elittle made like 190awhp with a turboback and chip. The haldex makes dynoing a b!thch, its best to just do it in fwd.
I would say 175-180awhp
5Speedwtneed
Nov 2, 2010 10:44 AM
Cpark07
Jul 12, 2008 04:24 PM
ocielz
Oct 18, 2007 05:40 PM
ocielz
Oct 18, 2007 05:16 PM
ocielz
Aug 3, 2006 03:29 PM
