Boost in First Gear
Old Feb 17, 2008 | 07:05 AM
beachchair's Avatar
Default Boost in First Gear
I run an APR 93 chip.
In upper gears: If I give steady gas, I get 15-16 lbs of boost
If I mash the gas, I spike to 20-22
In first gear no matter how I treat the gas, I show no boost. The car comes on quick, and I hit red line almost immediately, so I don't believe there is a problem. I just find it unusual that no boost shows.
Is this normal?
Thoughts?
Old Feb 17, 2008 | 10:39 AM
tom1222's Avatar
Default RE: Boost in First Gear
Perhaps a problem with your boost gauge? Are you running a Boost Machine or other MBC? You can dial in how fast the boost comes in and smooth out power delivery with the bleed off valve. Works wonders.
Old Feb 17, 2008 | 11:47 AM
cincyTT's Avatar
I'm make believe
You jsut dont make the same amount of boost in first and sometimes second due to load/gearing.
vdubb2bmw
Mar 2, 2010 12:27 PM
vdubb2bmw
Mar 1, 2010 12:36 PM
vdubb2bmw
Feb 28, 2010 07:25 PM
Red_sapphire89
Feb 23, 2008 05:26 PM
kaklexicon
May 1, 2006 05:05 PM
